- Joined
- 24 Dec 2024
- Messages
- 12
- Reaction score
- 1
- Country
I'm trying to replace a old 40mm waste pipe but the new pipe is to tight in the hole so I need to knock off the brick where it's catching so is it best to buy a sds drill with chisel function or can I buy a tool that will grind down the brick with a normal drill. If you recommend me buying an sds drill can you recommend one that's not to expensive but is capable of using core drills.
