Grand! That sounds like a plan. But it looks like the router cutter I need is out of stock. Bugger!how thick are the boards or bullnose ??
one pass on the top and one pass on the bottom take the board thickness say 22mm deduct 3mm that gives you 19mm half that is 9.5mm so get that radius as you need a 3mm flat on the nose to run on
https://www.wealdentool.com/cgi-bin/sh000001.pl?WD=4 1 round cutters&PN=Online_Catalogue_Large_Ovolo_Round_187.html#aT1332
if you are cutting say a 30mm wide bit off timber then get say 69mm wide bit off timber run along both edges top and bottom then cut in half
Yes, I would buy it from them buy it from Wealden but it is out of stock. I'll email to ask when they are due to have it againif its 21-22mm timber yes although Wealden tools own cutters tend to be cheaper
The small print says that the cutter comes with two bearings, one creates the step and the second one is for rounding offyou won't get a bullnose with that cutter you will get a step you need a cutter where the bearing is exactly the came size as the the cutter
