D
Deleted member 174758
Cutting a bullnose requires a cutter which works the whole edge, so it can't be done properly with a bearing guided cutter 9which will produce a step). Best done with a router in a router table and a fence
Maybe I should find someone to do this for me because I don't have a router table.Cutting a bullnose requires a cutter which works the whole edge, so it can't be done properly with a bearing guided cutter 9which will produce a step). Best done with a router in a router table and a fence
Yes, but it doesn't need to be exact. Providing the radius is equal to or more than half the thickness of the material it will produce an acceptable result. To help you visualise the difference in how they look the 11mm radius is on the left, a 16mm radius is on the right in this sketch (on 22mm stock):With this equivalent cutter that is sold by Axminster https://www.axminstertools.com/axca...tter-d-38-1-x-32-r-11-1mm-s-1-2-12-7mm-666192 that has a radius of 11 mm, would its dimension "A" be 22 mm?
My workbench jaws can be moved to make the opening wider so that should be fine.b&d workmate may not take a large router as the jaws only open about 5 1/2"/140mm
You're right, b&d workbench is a bit low. Your design looks the bee's knees but I don't have the space to store it. That's why I thought of the b&d bench as a base because it's foldable. But I take your point it's not ideal.Ideally I'd aim for a work surface height at 800 to 1000mm above the floor) or more or less the height your wrist is at). I find that Workmates are fairly low, at least for my 6ft 2in frame, and that when I made up a router table for one of those years back I ended getting tremendous back pain using it, so I made up a box, a bit like this:
Two extra lengths of sheet material as "legs", two bits of 2 x 2 to fix the top to the ends and a 2 x 1 front and back to tie it together. Loads of other ways to do this. Note the push block for end grain routing (in green)
I guess so. I'll give it a go. Many thanksThat's really just a quick and dirty design, a result of the site-based nature of most of my work these days. There's no reason why you couldn't screw it together and unscrew it and store it flat between uses
