Hi all,
I work for myself offering IT support. I often do CAT5/6 cabling and if additional electrics are needed I advise that the customer needs an electrician to do the work.
I was on a job last week and whilst under a desk plugging in my laptop, I noticed the socket spark, I took the front of the socket off and the live was loose. Now I could have fixed this in no time, but instead I put the cover back on and advised them that they had a dodgy socket and needed to sort it ASAP and in the meantime I advised them to pull the breaker - they wouldnt do this as it meant all the pc's in the office would go off.
Now this incedent made me think, what can I cand cant I do when onsite. I have no qualifications in this field, but my ability to actually do the work is ok, I know how house wiring works, am able to add sockets,lights etc, fit a shower (paid a sparky to fit a new consumer unit) but obviously what I do at home and what I do on site arnt the same.
Would I have been allowed to repair the above fault? all it would have involved was oushing a wire and tightening a screw! What if I need a longer power cable, can I put a plug on one end, an IEC (kettle lead) on the other of a cable to make a longer cable? can I change a fuse even?
I looked through my insurance policy but didnt really mention much, the only restriction I have is the use of heat (not sure if this refers to soldering or use of a heat gun or is aimed at blowtorches,oxy kit etc I'll check this on Monday)
Any advice welcome.
Any advice welcome.
