I didn't post a list, but mine gos:
1 Prelim. electrical checks, fuse rating and earth continuity
2 Visual inspection of appliance, clearances, suitable materials, any signs of damage etc.
3 correct operation
4 burner pressure, flame supervision device and initial exhaust emissions test
5 remove case and visually check the seal
6 vacuum and brush out burner, heat exchanger and pilot and check for any water leaks
7 Bit of fan spray in the bearings
8 reassemble, fire up, check gas tightness of disturbed joints, check case seal tight, check flame picture
9 check the operation again, emissions test again and run prelim. electrical checks again
This is just for an annual service on a fan flued, electronic ignition, room sealed combi......insert tea and biscuits between 1 and 5
