whats have i done wrong
2 Oct 2007
hi there
problem is.. theres a ring going around the first floor of the house... in my bedroom i changed a single socket to a double.. i have a radio alarm plugged into it.. i also took a spur of this to the other side of the room to a new double socket... (about 8 metres) i tested all the sockets they seemed ok, however now one side of the spur doesn't work...
i tried it with a lamp and heard a staticy noise and now it just doesn't work...
other side seems to work fine which my t.v is plugged into..
any idea what may be up..
p.s there all brandnew mk switches..
thanks guys
loose connection? damaged cable?
if you mean that on the double socket one side works and one side doesn't, take it off and fit a new socket. might be a damaged switch. all other connections inside the socket are metal strips.
but first check another appliance on that side in case it is the appliance, flex or plug that is faulty (this seems more likely to me)
