It varies, on logic plus the screwhead is pretty much flush with the faceplate, so certainly touchable. On the other and accessories designed for screwcaps (whether or not the screw-caps are actually fitted) tend to ave deeply recessed screws,
True, but I still think it extremely improbable that anyone would get a significant shock by that process.It varies, on logic plus the screwhead is pretty much flush with the faceplate, so certainly touchable. On the other and accessories designed for screwcaps (whether or not the screw-caps are actually fitted) tend to ave deeply recessed screws,
Which could mean the 'fault' could go unnoticed for a long time, until someone finds it.As I've said, it depends upon how ultra-cautious one wants to be, and it's not for me to knock the ultra-cautious.
It's pretty difficult (probably even for children) to touch the head of a faceplate screw in a plastic accessory (particularly if it has been tightened enough to damage insulation in the manner you describe) and, even in the extremely unlikely event of the screw being 'live', one would be very unlucky to not only manage to do that but also to find something else earthed to touch simultaneously.
Kind Regards, John
Indeed. In fact, I would think that in a high proportion of cases (of something which itself is very rare), it may well go unnoticed 'for ever'. However, that's really just another way of saying that it is extremely unlikley to result in anyone coming to harm.Which could mean the 'fault' could go unnoticed for a long time, until someone finds it.
Depends.Are fly leads between the fitting and back box required?
I would probably combine your two options and say "deemed inadequately 'necessary' to justify the cost"Why don't plastic switches have a metal bar riveted to the screw holes and an earth terminal so that the screws will be earthed? Cost - or deemed unnecessary?
Quite so - and it's similar to quite a few of the 'concerns' that are frequently discussed here. I am undoubtedly regarded by some as being unwise, perhaps even 'reckless' because of some of the things I often say about 'incredibly small risks' but when we get to the stage (as I just have) of questioning whether an extremely small theoretical risk has ever been realised (in all the decades of electrical installations), I do think that some 'realism' or common sense is probably required - not the least to put some of these 'incredibly small risks' into perspective in relation to all the risks which inevitably exist in life!Yes, I always think that when people mention touching the screws in face-plates.
Yes, I almost wrote that myself. I would think that, even if someone somehow managed to get a shock in such a fashion, it would be of extremely short duration, since virtually any muscle response (voluntary or involuntary) would result in 'disconnection' from the screw head.It would be rather difficult to 'touch' one in a way that an electric shock caused muscle contractions such that one could not let go (of the screw).
I'm not quite sure what you are saying,unless it's just 'a statement of the obvious'.The flylead is a requirement in the regs, when the only cpc is connected direct to the metal back box, essentially when the only cpc is via metal conduit, 2 core swa armour, micc pyro or similar
True - particularly when there is a metal insert into which the screw goes, since there then has to be plastic around it to keep it in place. Having said that, I've certainly seen conductors 'trapped' in plastic boxes, although I don't recall any having come to any significant harm as a result.Something else i've noticed is that plastic boxes tend to have large "bosses" around the screws, this dramatically reduces the chance of a wire getting trapped compared to metal boxes which just have the lugs floating in mid air.
An argument otherwise known as Survivorship Fallacy. Not worthy of you.Having said that, I've certainly seen conductors 'trapped' in plastic boxes, although I don't recall any having come to any significant harm as a result.
Kind Regards, John
Anecdotes are essentially meaningless, so you're probably right in terms of my personal (very limited) personal experience.An argument otherwise known as Survivorship Fallacy. Not worthy of you.
