Where to get 150mm screw drill bit from?
20 Aug 2012
Yorkshire
Searched around and unable to find any for no 7 screws for some sleepers I bought. Any help guys? Thanks
i assume you mean 7mm screws as number seven are about 3.5mm
Yes, thanks, I was searching for a while last night and unable to find anything, maybe because i was using the no 7 bit in there, thanks for that!
I just made some veg boxes out of half sized railway sleepers. I attached the corners using 200mm M8 coach screws. To drill the holes I used a long masonary drill bit. If you have number 7's then I would use a m6 masonary drill bit but of course lay the drill bit and screw side by side first to check the screw is wider than the drill.
Hope that helps
