Where to install Drayton Wiser?
12 Sep 2022
Hi, I want to install Drayton Wiser in my home to control heating and hot water.
My question is where do I wire it?
In my house currently I have a 2 zone heating system (2 thermostats) and 1 hot water timer. Each of these are in different rooms, so which one do I wire the Wiser to?
I have a conventional boiler, with a meagflo in the airing cupboard, and my gas boiler in the garage.
Hot water (In Kitchen)
Zone 1 radiators (Hallway)
Zone 2 radiators (airing cupboard - connects wirelessly to a thermostat - that looks similar to the zone 1 thermostat)
Megaflo (In airing cupboard)
Boiler (In Garage - No wiring present)
thanks.
The wiser is wireless thermostat’s and a 1/2/3 channel receiver, I’m guessing you bought a 2 channel? Either way the receiver would be wired into the wiring center in the cylinder cupboard. All other wiring will need to be joined or removed at wiring center and replaced with ones for the wiser.
The Wiser base can go where you want, unlike Hive which needs be be in a room under 22 degrees.
As to two or three channel personally I would convert to two channel, officially it says OpenTherm is single channel only, but seen reports it works with two channel.
But one first works out what you want to do, then how to do it, seems odd to buy Wisser then work it out.
Where have you read that the Hive receiver needs to be in a room below 22 degrees c?
I seem to remember Hive's own web page, the wall thermostat at the moment stops accepting demand for heat after 22ºC so if the room is over 22ºC then the TRV's in other rooms will not work.
