    Dismiss Notice
Where to put isolator for bathroom fan
Discussion in 'Electrics UK' started by mrbg07546, 6 Feb 2017.
  1. mrbg07546
    mrbg07546
    8 Sep 2012
    726
    Thanks Received:
    4
    West Midlands
    Country:
    our sparky is about to wire our bathroom fan. The standard place to put isolator is above door. Which I don't think would look great as it's in hall way.
    Any other suggestions where to put it.
    We have a loft conversation as was thinking of putting in a small area there??
  2. endecotp
    endecotp
    2 Dec 2013
    3,384
    Thanks Received:
    422
    Country:
    It is normally OK for it to be in the bathroom, if at ceiling level.
  3. mrbg07546
    mrbg07546
    8 Sep 2012
    726
    Thanks Received:
    4
    West Midlands
    Country:
    On the ceiling? Or high up in the wall?
  4. ^woody^
    ^woody^
    3 Sep 2006
    28,251
    Thanks Received:
    3,573
    West Mids
    Country:
    You can put the isolator down in the garage if you like, as long as it satisfies the requirement for isolation and can not be switched back on if the fan is being worked on.
  5. mrbg07546
    mrbg07546
    8 Sep 2012
    726
    Thanks Received:
    4
    West Midlands
    Country:
    Ok I've seen some "zone diagrams". There's area in my bathroom which are outside zone 2. Can I position it there?
  6. endecotp
    endecotp
    2 Dec 2013
    3,384
    Thanks Received:
    422
    Country:
  7. JohnD
    JohnD
    15 Nov 2005
    62,819
    Thanks Received:
    3,317
    Darlington
    Country:
    Cook Islands
    Which is above eyeline and not conspicuous.
    Unless you choose to have white walls and a purple switch, or vice versa.
    Chances are there are several switches and sockets in your house that are not hidden. This is generally considered to be quite normal.
  8. ^woody^
    ^woody^
    3 Sep 2006
    28,251
    Thanks Received:
    3,573
    West Mids
    Country:
    Isn't it up to the electrician who will be certifying the work?
  9. Sponsored Links
  10. mrbg07546
    mrbg07546
    8 Sep 2012
    726
    Thanks Received:
    4
    West Midlands
    Country:
    Yes and he said above door. And I wanted to ask about other people's options before he comes and doesnwork
  11. ^woody^
    ^woody^
    3 Sep 2006
    28,251
    Thanks Received:
    3,573
    West Mids
    Country:
    Then ask him to tell you all the places that it could be fitted, and then pick one.
  12. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    You don't have to have one at all if you don't want one.
    • Like Like x 1
  13. stubob
    stubob
    17 Jul 2010
    18
    Thanks Received:
    Leeds
    Country:
    You could use a 3 pole pull switch.
  14. JohnW2
    JohnW2
    28 Jan 2011
    42,897
    Thanks Received:
    2,726
    Buckinghamshire
    Country:
    Theoretically, yes (assuming you could find one) - but there's probably no need for a functional switch (it's probably operated from the light), so it seems a bit much to have a string dangling down all the time so that the fan can be isolated once every few years, if ever! As has been said, there's really no need for an isolator at all.
    Kind Regards, John
  15. securespark
    securespark
    11 Jan 2004
    34,224
    Thanks Received:
    1,052
    Country:
  16. JohnW2
    JohnW2
    28 Jan 2011
    42,897
    Thanks Received:
    2,726
    Buckinghamshire
    Country:
    Thanks. Yes, I rather assumed that they probably existed (but didn't bother to look!). I can but presume that they exist because some people want to use them as functional switches (not that manually-switched fans are all that common), doubling as isolators - since, as I said, it would seem very odd to have a pullcord only for 'once in a blue moon' use for isolation!
    I realise that most, if not all, of them have mechanical indications of their state, hence acceptable for isolation, but I have to say that (probably irrationally) I'm not sure whether I would feel totally comfortable working on something that was isolated by a pull switch. In what is probably a silly way, it just doesn't sound/fee "right" to me! Those who insist that an isolator has to be 'locked off' would presumably have a particular problem!
    Kind Regards, John
Loading...
Share This Page
