Which Finish for a Pine( softwood) Garden Table?
6 Jan 2015
Hello All,
I am enjoying making a garden table out of pine softwood. Stud partition for the table top and
thicker pine for the legs, not started the legs yet.
I thought at first paint. Knotting, primer, undercoat, gloss. Not sure now so I have decided to ask you what you have used for external pine.
What do you suggest please? What do you think, and how you got on with what you chose.
Keep healthy.
Consider checking out the Sikkens range of products that will sink into the wood, protect it and colour it if you wish. Expensive maybe but worth every penny.
I don't think that gloss painting is a good move for outdoor furniture personally but that's just me.
John :)
Check out the Bedec range, barn paint in particular. Gloss will ruin your hard work.
Nozzle
Dear me, two replies, both say keep away from gloss. Thanks,paint is out for me. I'll check on the stuff you mention.
Thanks for replying so promptly
Alan
Definitely not paint. I've used Sadolin in the past and been happy with the results.
If possible use pressure treated wood. I used decking for the top (smooth side up) and fence post for the legs - all pressure treated. More rustic than fine furniture but strong. Finished with outdoor water based varnish to seal which i know will need redoing every few years but hopefully no rot.
Thanks everyone. You have talked me out of painting but what about knotting solution. Ok for painting I am told, but these oil, varnish, epoxy etc finishes, do I knot those?
softwood knots bleed when the sun gets on them and they warm up. But you can get a lot of the resin out by playing a hot air gun on them, it will liquify and bubble out and you can remove it with a scraper before it sets.
Not hot enough to scorch the timber; though if you do, you can sand it off.
