Which method to lay a wooden floor & which long trims?
21 Aug 2009
London
Bit of a long one, any expert layers of wood flooring please bear with me.
I have a job where I am laying a solid wood floor on an old parquet type floor. (My client doesn't want to restore the parquet to original condition.)
The room is a square shape and a corner will be tiled as it will be used as a kitchen.
Can anyone with some knowledge of laying wood floors give me their thoughts on the best method of laying it please. If it weren't for the tiled section in the corner of the room I would lay a dpm and lay the wood onto adhesive underlay, although since the wood floor is going to end in the middle of the room and swap to tile I don't trust the adhesive underlay to be strong enough to hold the last row of wood never mind for years to come, especially if footsteps will be crossing over it regularly to reach the kitchen space. With this in mind I am thinking of laying it directly on a flexi adhesive (as recommended by a couple of flooring companies).
I was set on this last option although now I'm wondering if batons and secret nailing would be a good idea instead. Can anyone give me their thoughts on what's the best method for a lasting finish, adhesive underlay, adhesive direct or batons and secret nailing?
My second question is about where the wood section swaps to tiling. I need a long reducer but the only reducers I've seen so far have only been up to 1m long for use on door thresholds; I need something longer as where the wood floor will meet the tile floor is in the middle of the room and the edge runs for a few metres (3 I think). I imagine using 1 metre long reducers end on end would give a poor looking effect. What is the best thing to use here? Is there such a thing as a long 3-4m long reducer? I've seen wood floors reduce to other floors in this way looking fantastic when done well, sometimes with an octagonal edge to give a decorative finish to a square edge and I think it looks really smart. I'm looking for a classy looking finish - what's the reducer/trim that I need for this please?
Many thanks for any help.
R.
Never, ever use a DPM on an exiting parquet floor! It will cause too much condensation and blocks the normal evaporation of moist underneath the parquet floor.
Either use flexible adhesive or indeed the self-adhesive underlay - without DPM! - it is strong enough to hold the floor together even if there are tiles at one end.
On the other hand: because it is an open plan, with a kitchen - more moist - solid Oak would not be my first choice, wood-engineered would.
As for longer thresholds: we can supply lengths of 2.4 meter long
Thanks for that, much appreciated.
By the way the kitchen part is going to be tiles so the rest of the room shouldn't get wet directly. Solid wood should be ok shouldn't it?
thanks
It's not about getting wet directly, it's the effect of more moist (cooking, washing) in the air that can cause problems with a solid wood floor. Wood-engineered boards are better suited for this due to their construction of cross-layered backing.
