Two bearings needed (6202)......2RS are rubber sealed, and 2ZZ are metal sealed.
I use 2ZZ bearings all the time.
If you find the bearings stuck in the housing, heat the housing with a hot air gun and the bearings will drop out.
If they are stuck on the motor shaft, either use a puller or grip the bearing in a vice, and gently tap the rotor shaft end.
John
John
