Which Router Bit to Make a Flat Cut?
10 Mar 2007
Essex
I'm very new to the use of routers.
I've had my walls skimmed and now the walls stand a mm or two proud of the door frame. I'm putting on new architrave and so that it sits onto the door frame (flush) I want to reduce the thickness of the architrave that overlaps the wall. Do you call this a recess?
Anyway, I've got a router, but no "bits". What do I need to go and buy "bit" wise?
Hardest part will be holding the architrave still while you route it, it will need to be layed face down.
You can then make several passes at 2-3mm deep using the router fence against the outside of the architrave. something like the T219M will be the best bet as its more useful in the future than a surfacing bit
It would be better to buy a small router table to hold the router, then move the wood. You should also have feather boards. Alternatively buy a rabbit or rebate plane and do it by hand. See here for router info. here for rebate plane.
