Up to about 40 years ago, Earths were not required to ceiling light fittings, since they were then considered not to be in an "Earth situation".Do you not run earth wires to light switches then? Are there no metal switches?
An Earth connection is now required to be "available" at all light fittings, even if there is nowhere to connect it on a plastic fitting - since such a fitting may later be replaced by a metal fitting requiring an Earth.
(Also, a RCD or RCBO is now required on all new/upgraded lighting circuits.)
If the Active/Line, Neutral and Earth are run to the light fitting, there is no requirement (at present) to provide an Earth (or Neutral) at the Switch.
If the Active/Line, Neutral and Earth is first run to the switch positions, the Neutral and Earth is (of course) available at the switches.
https://www.energysafety.govt.nz/documents/legislation-policy/electricity-act-regulations-codes/standards-and-codes-of-practice/NZECP 51 2004 New Zealand Electrical Code of Practice for Homeowner Occupiers Electrical Wiring Work in Domestic Installations - Published 27 July 2004 .pdf tells New Zealand homeowners what electrical wiring work they may legally do (and what they may not) - none of which is now allowed to homeowners in any Australian State. (However, Bunnings and the electrical wholesalers sell the things that are required. (To stop them would be "restraint of trade".)
All light switches (and socket outlets) are actually plastic with no touchable metal parts which require Earthing. The metal securing screws are deeply recessed and can be accessed only with a “tool” – which is the requirement, at least since about 1945. There is also a requirement that they be “covered” and plastic inserts (and two spares) are supplied with all wall-plates which do not have separate covers - as most do today. (See https://www.bunnings.com.au/hpm-10a-white-double-powerpoint_p7053733 for an old style plate with plastic inserts.)
However, while these inserts often get left off after the plate is removed and replaced, the tightened screws cannot be touched by the finger of an adult or child without using a tool.
Even with wall-plates which have “metal” finishes, the metal is a thin layer on top of the plastic cover-plate and is actually “double insulated” by the plastic switch body and the cover-plate from any Earth (or Line) connection.
Some of these DO have metal screws which are touchable, but these are NOT the screws which secure the switch plate to the wall - which are towards the extreme ends of the wall-plate. These are the screws which secure the cover-plate to the plastic body of the switch and are somewhat closer to the centre.
https://commons.wikimedia.org/wiki/File:Typical_Australian_Rocker_Switch.jpg
https://commons.wikimedia.org/wiki/File:Australian_Light_Switch.jpg
https://commons.wikimedia.org/wiki/File:Australian_four_gang_wall_plate.jpg
https://commons.wikimedia.org/wiki/File:Australian_Architrave_2_Gang_Switch_Plate.jpg
may be of interest.
https://commons.wikimedia.org/wiki/Category:AS/NZS_3112_sockets also may be of interest.
