Why do new houses
what if there is no hot water in the tank will the boiler also heat the water on demand?
if we was to replace the boiler would it just be a simple boiler swap with the rest of the system staying the same?
This is why I wrote that.
Firstly you ask if a boiler can heat water on demand through a STORED water cylinder full of cold water.
Then ask if you can change from a combi system to a traditional system (which would require a HW store) with just a boiler swap.
