As a rule a comport should be programmed as not used to connect a usb com and use wintex.
Unfortunately the com port adapter Texecom used to supply with the smart com no longer is and has to be purchased separately.
If you have a smart com connected then you don’t need to be using a usb com lead in the first place.
