Hello there ,
Before I download wintex from Texecom, I need to know if it is possible to tranfer settings form a Premier88 v3 to a new premier 88
I moved in a property 8 years ago and the system was already fittet to the property, It has been working perfectly and still is
But because I now want to install a ComWifi inside the panel, it need version 7 or higher for the comwifi to work.
Therefore I can flash the firmware or fit new panel, I heard that sometime people have problem flashing and ended up throwing panel away. So I decide to replace to identical panel with up to date firmware.
I have not used Wintex before , so need to know if i can save the present panel settings and once the swap is done , transfer the settings to new panel.
Is this feasible,
Thank you if you can help
Is this feasible,
