Wireless boiler thermostat keep says find ...
9 Aug 2021
Hello,
I have a wireless thermostat ( British Gas SLT 2) which stopped working after being turned off over the summer. My boiler also showed a pressure of zero hence I have just topped up the pressure to 1 today. No lights are flashing on the boiler and hot water has been running fine. But when I tried to reconnect the thermostat with the boiler it keeps saying find on the screen. And after a few minutes it shows timeout.
9 Aug 2021
9 Aug 2021
Yes I have replaced battery several times now. It is a wireless thermostat. Now every time I put in the battery it just says find, and with a timer, then after a while it says time out
CBW
26 Sep 2019
North
Have you tried re-binding it as per link, and is the receiver on and working?
9 Aug 2021
I managed to find the box which shows a red light on the status. I am thinking to reset it but as I just moved in and I don’t have this device on the app. Is there a way to reset and pair it to the receiver without the app?
9 Aug 2021
This standalone box is now flashing double amber... the official manual says to enter the pair mode by setting from the app.. but this is a stand-alone thermostat hence no hub and not connected to the app... how can I turn this into a pair mode now anyone knows? It has been flashing double amber for the past 30 minutes and my flat is hot like a sauna place
15 Aug 2010
Livingston
sounds like the previous tenant/owner has taken the hive hub with them
27 Feb 2017
Essexshire
Even if they didn't take the hub, I think you would need their login details to get the app working. I thought you only needed the hub to control it through the app and could use it as a stand alone unit. In fact I know you can. My mum has a wireless Gen 2 Hive thermostat and receiver and she definitely doesn’t have the hive hub or app.
9 Aug 2021
actually - got it working in the end without the hub. If you restart the receiver and press it until it flash pink or white that means it is ready to pair without the hub. And then I managed to connect it back to the thermostat
  • Thanks
Reactions: CBW
9 Aug 2021
Hope this is also helpful to those who does not a hub. Don’t press it till it flashes double amber ! That way you need to pair it via the app. But press it until it flashes pink/ white
1 Jan 2022
Hi I'm having the same problem. I have the pink light flashing. How did you connect it back to the thermostat? Did you have to press any buttons on the thermostat? The message I have says Rejoin. When I tried earlier it eventually said Timedout.
