wireless wi-fi router
27 Jul 2008
Middlesex
hi guys,hope you can help with this one,got a black spot in the house cant get no signal for net,do they do a wireless wi-fi extender have got a wired netgear router a the mo,any help or advice would be great,cheers guys
21 Jan 2013
Yorkshire
You could look at a simple powerline device.
Plug the brick into the wall socket at each end and connect one to your existing router and the other to your computer in the black-spot.
Alternatively connect a cheap WiFi gateway to the powerline brick in the black spot if you want to use WiFi.
One small point that is often missed when extending a WiFi system. You need to put the extender in a spot where it can receive your current WiFi at a decent bitrate and also will supply a WiFi signal at the required bit-rate in the black-spot. That is not always an easy thing to achieve, consequently I recommended a powerline solution to bring your network into the black-spot area. You can then use a wired or wireless solution in that area as you require.
Hope that helps.
Gary
Similar threads
