i am wiring a cupboard light from existing switch in lobby ,the switch has 3 cables and an earth ,does my new light have to have as many cables. thanks :
You will not be able to wire your cupboard light from the switch. There is no neutral there.
You will need to pick up live, neutral and earth from the lighting circuit - usually this can be found at a ceiling light.
This is not what you want to hear.
If lifting floorboards and chiseling out your walls isnt part of your plan then the next best option is to add a 3A fused spur to a nearby socket and power your lights from there.
No. Why would you connect a NEUTRAL to a switch? A switch simply makes or breaks a contact between 2 wires. If the 2 wires are live and neutral, what happens when you make the contact? BANG!
I suggest you get an electrician to do this work for you. The phrase "does my new light have to have as many cables" does not inspire confidence in your ability to do this work.
There may be a neutral in the switch if the loop exists in the switch rather than at the ceiling rose. It sounds like this may be the case if you really meant there were three cables at the switch rather than three wires
hi cant send picture at this time but i have 4 wires coming into switch blue onto L2 yellow onto L1and red onto the top with the earth onto back plate thanks
