I’ve just removed my old doorbell, which was wired through the mains (replacing it with a more modern cordless doorbell).
This left me with a bit of mains flex sticking out of the wall just above my fusebox in a hallway cupboard. I’d like to use that to power two 11W LED ceiling lights (bought from Screwfix last week) - one in said cupboard, and one in the cupboard next door. Also a simple 1 way switch on the wall of each cupboard.
Is there a handy wiring diagram out there that I could use? And the circuit that this mains lead is on (“smoke alarms and doorbell”) isn’t protected by an RCD, so will I need to fit one of these as well?
Is any wiring to/from the lights and the switches best done underneath the plasterboard, or is surface wiring ok (inside plastic trunking, which I have lots of)?
For the moment I’ve terminated the lead inside a junction box (pending my next move) rather than just leaving it dangling.
I could get an electrician to do this of course, but I’d quite like to do it myself (cheaper and more satisfying) - but only if I’m sure I can do it legally and safely.
Thank you.
Thank you.
