I recently purchased a new dual fual range cooker. I was surprised to find that no cable was supplied to connect to the outlet terminal. The electric ovens are rated at a combined 7.3kW.
I have run 10mm T&E cable to a double pole isolation swith from the CU. This then runs to a terminal outlet. I now need to run a cable from the terminal outlet to the cooker, but do not know what type of wire is needed. It says in the instructions that the cooker is of type 'X' (relating to heat insulation, or something). Is their a special heat resistant flex that is used to connect cookers to a fixed terminal?
Any help would be appreciated, as I am starting to get fed up with microwave meals!!
