Hi.. Hoping someone can help.
I would like to wire in a new wall light purchased from Focus.
Wires - Wall - Brown Blue and Earth All attached to plastic junction box (3 holes with screws etc)
Light - Metal body and metal bracket (to fix to wall)
- Light has Brown Blue and earth wires
- metal fixing bracket has earth wire connected with screw fitting to the wall bracket.
I have (turned electric off). attached wall bracket and connected Blue to Blue, Brown to brown and Earth of light to earth of cable coming out of wall... All via the plastic junction box Light works!! yippee (but attached light to bracket and it doesn't work... )
Connected Earth from wall Bracket to earth (from Light) in plastic box and it doesn't work
Connected Earth from wall Bracket to earth (from wall cable) in plastic box and it doesn't work. (Earth cable from light is still connnected to plastic box)
Taken off earth from wall bracket and not connected it to anything (covered with insulation tape) and light works, but as soon as you put the light onto the bracket it stops working.
In all instances the earth from Wall cable is in the box and the earth from the light is in the box.. I just can't understand why it is not working.. Where should the earth from the wall bracket be connected to???
Hope the above makes sense, I am sure it is something simple and I just can't understand why it does work.. surely if all the right colourd cables are connected to the same colour cables it should work.. and the light does work cause it works when the Earth from teh wall bracket is not connected to the wires ( I know it needs to be connected) as soon as the light is fixed to the bracket it trips the lectrics..
HELLLLPPPPPP
HELLLLPPPPPP
