- Joined
- 11 Jan 2004
- Messages
- 42,867
- Reaction score
- 2,664
- Country
breezer said:have a really good look (you may need magnifying glass to see)
That's a bit mean, isn't it?
Lectrician said:Modern ELV ones usually are a combination of series and parallel.
breezer said:Lectrician said:Modern ELV ones usually are a combination of series and parallel.
to avoid confusion:
the above is tue. but they are sets of 20 (which are in series) in paralell this way you get sets of 200+ lights
Lectrician said:The instructions always say to replace bulbs quickly, this is because the shunt resistor doesnt drop the full 12v. The other bulbs age quicker with one blown .
Not true, there are sets that have a small coil of wire around the filament legs that allow the string to keep working even if one or two lamps have blown, although i don't approve of such lights ( the more that blow the brighter the others become as the voltage increases across the ones left)breezer said:no they don'tplugwash said:modern mains series christmas lights have all but one bulb (the fuse bulb) designed to fail short
have a closer look at one
all christmas tree lamps fail open, that is why they fail, the filament is burnt out and is open
So how do the lamps work? How/where is that coil of wire connected when the filament is intact and the lamp is working normally?kendor said:Not true, there are sets that have a small coil of wire around the filament legs that allow the string to keep working even if one or two lamps have blown,
Would you rather the users of such a set had the problem of replacing each of up to 60 or 80 or whatever lamps one-by-one on a trial and error basis until they found the one which had blown?although i don't approve of such lights ( the more that blow the brighter the others become as the voltage increases across the ones left)
the fact is they do exist.
