i am fitting a cda dual fuel range cooker .
the plate says 14.5 kw . 1054.8 g/n 230v. 50 hz . 4089w.
my previous cooker plugged into the mains but i have found a 4mm cable that supplied my old heating system and is still live . it runs about 8 feet from my cu. and is taped off in an old cupboard where pump and valves used to be and is still live . i trust i can use this . it states an omnipolar switch can be used with a min. 3mm opening . what size switch do i need .
finally , what size heat resistant cable do i need from switch to cooker .
thanks for any help .
