- Joined
- 20 Oct 2020
- Messages
- 38
- Reaction score
- 0
- Country
Tables not faulty your floor is uneven.I bought this furniture village earth natural dinning table. It is a failure. It is wobbly. Because of the faulty design. The X shape base. Any idea how to make it stable like four legs table?
Not it is not the caseTables not faulty your floor is uneven.
I completely agree what you said. All due to the faulty design.That's a terrible design and on anything other than a completely flat solid floor it will be a bit unstable even if the base of the table is perfectly flat. As mentioned a leg in each corner is probably the only effective solution.
Or are you saying the flat base is not securely fixed to the legs?
The branch don't think the same. No chance to return.Take it back, not fit for purpose on a wonky floor!
Andy
Not that bad but it really is not as stable as the traditional ones. I might replace the legs in the future.that table is a shocking design
if you have small childen 'young children 'older parents in deed any one that will swing or lean could have a bad injury as the table topples and falls on you parent or child that has done what comes naturally and now flat on the floor
half the table total weight will probably be on the table edge as it hits the floor further increased by momentum
try tipping it onto its side and see how much effort it takes to rotate back to upright thats the amount off weight would be resting on an adult or child under it on the floor ??
