Hi
I had a dripping kitchen tap replaced by a Dyno engineer yesterday. During the process the hot water pipe was leaking and he fixed it. Now I have found the hot water pipe (right one in the photo, it is under the sink) is a bit wobbly, in the vertical direction. When I touch it, I can feel the pipe moving a little bit up and down (a bit elastic, not stiff if you know what I mean). The cold water pipe (left) is very steady.
There is no leak right now.
I wonder whether it could be a problem, could it lead to loose connections and leak in the future? Thanks for any advice.
