I replaced the fuse, tried unplugging the blue burner cable, and it powered up OK. I connected the burner cable up again and it blew again. I went inside the wiring box, behind the control unit and disconnected the transformer, fan and oil pump wires: the fuse did not blow. I reconnected the oil pump: the fuse did not blow. I reconnected the fan: the fuse blew. I disconnected the fan again and reconnected the transformer: the fuse blew.
Does this mean both the fan and transformer need replacing? It seems unlikely that they would both have broken at the same time, unless one's fault damaged the other. I had the transformer disconnected from the electrode leads for these tests, is that OK?
Or does it mean the control unit is faulty?
I was obviously hoping to narrow it down to one component to replace, but now I am confused.
Any help would be gratefully received,
David
David
