worcester 24cdi
29 Aug 2011
Cheshire
im having a prob with my boiler when i turn my hot water tap on the pressure bar on boiler moves up an down between 1.5-2 then a loud banging and gurgling noise starts then steam starts coming out of the pressure re-lease thing ....help any ideas please :?:
when i turn the central heating on nothing happens , i turned boiler off and bleed the system then checked again but it didnt solve it. boiler still did banging and gurgling noise
ive been having to top up the system recently once a week at the least thought i had a leak on a rad but carnt find one and no sign of any on the boiler for the amount its been losing ,. do u still think it might be the pump still???????
Test the Pump as descibed in the FAQ's if your unsure.
Sounds like a pump to me. One of the simpler parts to change on this boiler.
do you think it cud be the heat exchange or the thermostat with it kicking the water out and me having to keep topping the water up weekly ?????
I have started to have the same problems with my boiler - can you tell me what was wrong with yours, how you fixed it.
Many thanks.
David
