Worcester 24SBi: pump working, no flue fan or ignition
3 Jan 2009
Berkshire
I would appreciate counsel from the collective wrt Worcester Bosch24SBi which today has decided not to work.
Symptoms as follows:
Room stat working
Pressure set at 1.5bar
Green mains light on
CH control panel to ON
1/ pump starts
2/ no flue fan
3/ no ignition
Checked all the normal stuff...... Anything you can suggest before I resort to my local gas safe chap ?
Many thanks
3 Jan 2009
Berkshire
Resort to the Gas Safe chap.
Thanks for your reply.
I presume there is some kind of air pressure switch issue or knackered fan thing.
Clearly beyond my technical competence - a note a new fan is around 85 pounds - so lets see what GasSafe chappie reports. will rpoert back.
3 Jan 2009
Berkshire
Just to close this out for future reference.............. Gas Safe chap diagnosed problem as broken flue fan. Now replaced, serviced and all working
Thanks for your help
3 Jan 2009
Berkshire
Well it seems its not fixed after all !
It now fires up and gets hot and so do the rads
But then it turms off and fails to re-ignite despite the temperature differential between inflow and outflow from the boiler being around 4 degrees
Also once it reaches its temperature its then seems to go into a slow shut down mode where its sits and cycles until them temperature differential is so small it might decide to reignite.
Does this sound like a thermister issue ?
