- Joined
- 14 Aug 2007
- Messages
- 119
- Reaction score
- 0
- Country
I've got the above oil fired combi to fit, The house requires 29Kw of heat.
The guy I'm working for has suppplied all the material and I noticed today that all the copper is 22mm for the main flow and return legs.
Now whilst looking at the boiler the heating connections are 28mm, Will 22mm copper supply 29kw of rads, I've had conflicting opinions and personally myself I think it will struggle.
The boiler is being fitted in an out building with approx 6M run into the main building, Would it suffice running 28mm from the boiler in the out building to where the pipes enter the house and then run the flow returns in 22mm copper.
The upstairs and down stair circuits will be tee'd off seperately in the out building so the downstairs will have a 28mm feed and the upsatirs will also have 28mm feed but again this will reduce to 22mm copper where it enters the main building.
Any pointers would be ideal.
