Worcester 28cdi hot water problem
31 Mar 2006
Hi, I have a worcester combi 28cdi.the problem is that the hot water is fine when the heating is on but when it is off I can't get hot water regulary down stairs and never up stairs. and when the water is hot down stairs it is running luke warm up stairs? Even though the burners are cumming on.
I was told it could be the diverta valve but would it run hot at all if it was?
Any help would be gladly recieved,thanks
Would imagine you will find it going round the heating circuit instead because the diverter is shot. You might get away with just the diaphragm, but it's often easier to take the whole valve off and replace it.
as I said in your other post matey :roll:
Nope get someone in do not do this yourself as they are tricky beggars
Just wondering if a faulty pump could cause this problem. It's just that I had another pump fitted (not new) when this started and it got slightly better.
I have noticed that the pump that is on it now is really hot to touch .is this normal?
