Worcester 28CDi RSF - hot water on the blink
19 Mar 2006
Lancashire
When a hot tap is switched on the piston on the diverter valve moves out and stops just shy of the microswitch - a scew driver blade in between the piston cap and switch sets the hot water running as per normal.
Can't face kneeling under the boiler whilst the family all take showers!
Advice much appreciated.
Done a diaphragm on one today . Managed to do it in position without removing any of the filling mechanism or plate heat exchanger. Removed right hand side panel and gas valve and used a long flexible screw driver. One of screws at back is a bit awkward to get in and out also think i was lucky to get it all lined up first time on reassembley.. The guy who designed the lay out on these should be given a good kickin.
I did one in situ last week for the first time,
I won't be doing it again, what a ball ache. :twisted:
Its easier just to get the whole valve out and change the diaphragm on the work top.
IMHO anyway.
Yeah agree with ya scatman . Just wanted to see if it could be done. Really don`t like doing them full stop
how did you manage that? the diverter cover that needs to come off to get the diaphragm out is slotted into the plate H/E by at least a half inch.
i use a right angled screwdriver for the screws and just remove the plate H/E, ive done a lot of them now and have it down to 50mins tops if there are no complications......quite often there are though :lol:
Nickso.. that little bit on top of divertor that you mention also houses the cold water restrictor an has a nut on it that when you undo slides down the pipe towards the divertor over the o ring.. But do agree could be easier just taking the heat ex off and the filling mechanism. And then fixing the leaks after. :lol: :lol: . Don`t know if you where issued with one but used the BG flexible screw driver and socket set excellent bit of kit.
ahh....ive never dared take that off for rear of screwing the plate h/e....chances are if its tight you'll disturb the crapp-y seals on the rest of the plate anyway
