1-flue needs to be sealed where it passes through the wall if a cavity wall sealed on both inside and outside.plaster for inside.sand and cement for outside.
if no attempt has been made to seal these gaps poc can creap into the bathroom,also making good the gaps also holds the flue in position.
2-check plastic cap on flue turret is hand tight and has a rubber seal inside it.
there you go.
there you go.
