    Dismiss Notice
Worcester 35CDI - Constantly On dispite Eco button - Costing me a fortune!!
Discussion in 'Plumbing and Central Heating' started by lucky1313, 21 Feb 2019.
  1. lucky1313
    lucky1313
    28 Feb 2011
    94
    Thanks Received:
    Blackpool
    Country:
    Hi Guys
    I've moved into a new home which has the above boiler installed, I noticed the boiler was firing up a lot with the fan running constantly, it was also consuming about 150-200w of electricity...all of this was happening when there was no heating on or hot water being run.
    So I had a read up on the Eco button and it looked like this would solve my issues, so I pressed the button and it went green showing it is now in Eco mode. That stopped the boiler firing up and down when not asked to but I'm still left with the fan spinning away and around 100w being in constant use.
    Is there anyway to calm this boiler down it seems really hungry on electricity and any money saved with it being a efficient condensing boiler seems to be getting wasted with it being constantly half powered up.
    Is this just how the boiler is designed as it seems crazy as it's costing me 2.4kw of electricity a day ( 40 pence ) even when I'm not using it.
  2. Sponsored Links
  3. ollski
    ollski
    8 Oct 2003
    6,690
    Thanks Received:
    432
    Bristol
    Country:
    Is it the 35cdi combi or system?
  4. lucky1313
    lucky1313
    28 Feb 2011
    94
    Thanks Received:
    Blackpool
    Country:
    It's the combi boiler, so does my heating and instant water nothing extra such as a water tank
  5. ianmcd
    ianmcd
    15 Aug 2010
    19,757
    Thanks Received:
    7,694
    Lanarkshire
    Country:
    there is a fault with the boiler it shouldnt be doing that
  6. lucky1313
    lucky1313
    28 Feb 2011
    94
    Thanks Received:
    Blackpool
    Country:
    thanks for the reply, so the fan should be shutting down completely and the power consumption should reduce to nothing ?
  7. ianmcd
    ianmcd
    15 Aug 2010
    19,757
    Thanks Received:
    7,694
    Lanarkshire
    Country:
    yes it should shut down not exactly nothing power consumption as the boiler display and monotoring system still use a little bit of power
  8. ianmcd
    ianmcd
    15 Aug 2010
    19,757
    Thanks Received:
    7,694
    Lanarkshire
    Country:
    the fan should run on for 30 seconds once demand is satisfied
  9. lucky1313
    lucky1313
    28 Feb 2011
    94
    Thanks Received:
    Blackpool
    Country:
    godamn that sucks, it's costing me money ...what do you think the issue might be ?
  10. Sponsored Links
  11. ianmcd
    ianmcd
    15 Aug 2010
    19,757
    Thanks Received:
    7,694
    Lanarkshire
    Country:
    could be a few things you will need to get someone to have a look at it
  12. lucky1313
    lucky1313
    28 Feb 2011
    94
    Thanks Received:
    Blackpool
    Country:
    Ok thanks for giving me a heads up I thought it was odd to hear it spinning away 24/7 but then I've never owned a combi boiler before so wasn't sure that was normal
  13. ollski
    ollski
    8 Oct 2003
    6,690
    Thanks Received:
    432
    Bristol
    Country:
    You sure it’s the fan?, faulty pcbs commonly keep the pump running 24/7
  14. lucky1313
    lucky1313
    28 Feb 2011
    94
    Thanks Received:
    Blackpool
    Country:
    definitely the fan spinning away at about 50% of max so it's pretty obvious..causing the boiler to vibrate too due to a few bolts being lose on the cover...piece of crap boiler ..that's 4th thing on it to fail in 3 months since I have moved in...Thank god for Worcester Boiler cover :)
  15. Gasguru
    Gasguru
    9 Sep 2005
    11,758
    Thanks Received:
    3,073
    Sussex
    Country:
    The front casing has a clip on the top and 2 screws underneath....they were loose?
    The CDi has been around for a very long time...very rarely the pumps can stay on but they are generally fairly robust boilers.
  16. ollski
    ollski
    8 Oct 2003
    6,690
    Thanks Received:
    432
    Bristol
    Country:
    I’d be checking external controls then first
    • Thanks Thanks x 1
  17. ianmcd
    ianmcd
    15 Aug 2010
    19,757
    Thanks Received:
    7,694
    Lanarkshire
    Country:
    if you have worcester boiler cover why are you on here asking ? just call them out
Loading...
Share This Page
