Hi everyone,
I’m hoping someone with experience of Worcester Bosch boilers can offer some advice.
I have a Worcester Bosch Greenstar 30CDi, and the boiler pressure keeps gradually creeping up during normal use.
The filling loop valve is fully closed, and the filling key has been removed, so I don’t believe water is entering through the filling loop.
The problem is that the pressure continues to rise throughout the day, and by the evening I have to bleed water from a radiator to bring the pressure back down.
Has anyone experienced a similar issue or know what might be causing this?
Could it be a faulty filling loop valve, a passing plate heat exchanger, or something else?
Any advice on what to investigate or ask an engineer to check would be greatly appreciated.
Thanks in advance.
Thanks in advance.
