Worcester Bosch Greenstar 4000Combi Boiler PRV
16 Dec 2018
Hi, I'm after some help, please. I've called a few gas engineers, but nobody has got back to me so far.
I'm having external wall insulation done soon, and I need to extend some piping on my outside wall (if required). Here is what I currently have. I know the white pipe above is the old condensate pipe and I've replaced this with a condensate pump, so it's no longer in use. (tested as well last week to confirm, as the old pipe still exists next to the boiler). The copper pipe is what I'm not sure about. I think it may be old PRV piping but need some clarification before cutting and insulating over.
The condensate pump pictured below has both the plastic condensate pipe and a copper pipe, which I believe is a PRV (I seem to remember this also when the installer connected it).
I think the PRV is this pipe
Which goes down to the pump.
Are my assumptions correct? Is there any other reason I'd have a copper pipe on my outside wall if it's not a PRV?
Thanks.
So... Care to share the Gas Safe engineers you've called?
Coz, if i had a call from you, I'd respond!
The installer for one and another contact I have. Nobody has responded, but it is the holiday season I suppose.
If you've had a condy pump fitted, those external terminations are fairly likely to now be redundant.
If you shone a torch down into the floor directly below the new discharge pipe, you might be able to see where the old one was cut and is still there.
Could also put a wet vac on it and go inside and see if you can hear/feel the suction. Or even spray some deodorant up it outside and if it's open ended inside you'll smell the deodorant.
Thanks, I will try this out (y)
Had a quick look tonight and can only see another plastic pipe (different from the old redundant condensate pipe). Will try the deodorant trick tomorrow. Google tells me that the PRV must be copper, so I'm not sure this other plastic pipe connects to copper further down under the house.
I take it you don't have an unvented hot water cylinder, your boiler being a combi doesn't rule that out!
No I don't, just a combi.
To me, it feels like this pipe is an old redundant pipe, possibly from a previous install. Clearly, I'm no expert, but I can't think of anything else that would require a pipe to the outside world if the current boiler's condensate and PRV is covered by the internal condensate pump.
