Evening all,
After taking my Worcester Heatslave out for a welded leak fix on the boiler, it has been making a strange noise since reinstalation.
It is definately inside the burner that is making the noise. To best describe it is to say it sounds like it is "stalling", as if the flame is going off then on.
As soon as I remove the burner outer cover the noise stops and it sounds like a Worcester Heatslave should sound. Put the burner cover back on and it starts "stalling" again.
The only two things I think it could be is a blocked flue or fuel starvation.
The reason I don't think it's a blocked flue is that when I take the flue top cover off (at the flue itself) there is no difference in noise.
The flexible pipes to and from the oil pump are new after market ones and are much longer than the standard Worcester ones. I thought they may be getting pinched when I put the burner cover on and stopping fuel flow, but it is difficult to replicate this.
Any other thoughts ??
