First off the laminate edging strips are generally available from distributors of the worktops and are an exact match to the laminate worktops, so a Duropal edge strip would come from a Duropal distributor. My own experience of this market is that the trade outlets may be happy to sell you a strip, but that they aren't on line as that's not where their main market is. Do you know what brand of worktop you have and the name of the range (e.g. Duropal U1233TC Metallic Black)? This should be marked on the underside of the worktop.
Scrit,
Thanks for the tip about looking underneath - never even occurred to me. Unfortunately it only gives the manufacturers name (Bushboard) but I've had a look at there website (www.bushboard.co.uk) and should be able to find it from there - o contact them for some samples to compare.
Cheers
