Right guys I have a bespoke curved ceiling where the curve is a drop ceiling.
Now this curve is if I use the terms correctly a cove i.e. where some strip LED can be placed to give a feathered lighting effect on the edges where the curve is.
Now on the base of this curved part of the ceiling close to the edge, I was wanting to add some small downlights but am afraid that since they are not fire rated i.e. open at the back they may backwash onto the ceiling above. Would this be the case or am I being paranoid for no reason?
Below are some photos of the curve
So to summarise if you look at the photos and follow the curve you can see it protrudes, in this protrusion there shall be some strip LED running all the way around. My initial intention is to add the downlights to thsi protrusion for two reasons. One there will be no frame work to hit so I dont need to take any studs into account when measurin around and secondly the cove part is at a distance away from the wall so its another worry i wont have.
My only concern really is the backwash bit.
Let me know what you think guys
NOTE:
The recessed downlights are similar to these only that mine are twist and lock at the front and also mains converted
http://www.toolstation.com/images/library/stock/webbig/12400.jpg
cheers
NOTE:
cheers
