On the current external side of my bathroom wall there is currently green plasterboard that was dot and dabbed. The thickness of the plasterboards look approximately 20mm. I’m ripping the plasterboards out from the blocks completely to replace it with 20mm xps backer boards. I’ve attached a photo below of how the blocks look and the current plasterboard looks.
What I noticed is that there is a considerable amount of gap between the block and the plasterboard itself. And whatever adhesive was used to bond it is super strong but what they did was had big thick layers of that adhesive which created quite a big gap where there is no adhesive.
My question is, when I now come to stick the XPS boards, I was planning to use rapid set tile adhesive and stick the boards on and after the rapid set has cured drill some holes through and use washers and screws for extra mechanical fixing. Will this work? Should I aim to not have the sort of gap that’s currently there?
If the block isn’t 100% straight could I just pack it with extra tile adhesive in problematic areas?
