- Joined
- 19 Dec 2015
- Messages
- 160
- Reaction score
- 4
- Country
Hi all I have the above issue, I have a hive active system with a worcester 18ri.
The problem is I am getting very low voltage coming from the orange wire from the 3 port valve approx 90v! this is when the heating only is selected and the hot water is satisfied. the boiler still appears to fire up and the pump runs. the pump is switched from the boiler as it overruns. about a month ago the cylinder thermostat was replaced. I can't help thinking its been miswired, the cylinder stat has a short piece of 3 core flex which goes to the wiring centre (brown,blue and Green & yellow)
I will do my best to explain the wiring setup, the pump cylinder stat and heating valves are all in the airing cupboard as you would expect all connected to wiring centre which is also in the airing cupboard. the boiler and programmer/receiver are in the kitchen. From the receiver two 3 core and earths run to the wiring centre
(in the wiring centre)
One cable contains from the receiver
Red=hot water on, this is connected to the brown which goes to the cylinder thermostat common
Yellow=central heating on, this is connected to the white wire to the 3 port valve
Blue=hot water off, this is connected to the grey wire from valve and the green and yellow wire which goes to the cylinder stat "2" terminal
Second cable
Red= boiler demand, this is connected to the orange wire from the valve and the blue wire which goes to the cylinder stat "1" terminal, the pump live used to be connected this terminal also but now has its separate live for overrun
Yellow= used to be spare but now supplies the pump
Blue= Neutral
earths obviously speak for themselves
third cable 3 core and earth went to the room thermostat this has been disconnected completely from the wiring centre due to the hive controller which just runs on batteries.
I would appreciate some help, the radiators are slow to heat up but that does not surprise me if the boiler only getting 90v, I am also struggling to understand how it could have worked on the old setup, when the pump wasn't switched from the boiler how the hell could it have worked before with only 90v?
I can only think the cylinder stat has been wired incorrectly, something isn't right, the cylinder stat in question is a honeywell L641A1039.
Hope this makes sense ,would appreciate some help
thanks
Second cable
Blue= Neutral
thanks
