A
ahdsh
Hi I am a YALE alarm expert after installing a hundred of the alarms over the last year so if you have any questions at all with DIY fitting just ask me on this thread..
I thought yale made locks?
I'll stick with an alarm manufacturer for my alarms.
Yea, but don't forget if an insurance company wants someone to have an alarm system, a Yale will not be acceptable, even if it is already in place.I thought yale made locks?
You must have misunderstood my post.
It was for people carrying out DIY installations wanting advice not for unneccessary droll comments.
If you don't believe Yale alarms work or are unfit for purpose then be my guest complain here http://www.yalelock.co.uk/en/yale/couk/Contact-us/
They read like they might be s***e!
I am a diyer and I would not even fit a yale alarm to a wheelie bin. Having that yellow bellbox box with yale on it says to burglars this is defiantly a diy alarm system fitted.
djrock
Just to get this subject rolling here are a couple of useful tips..
1. Always screw the magnetic door contacts in place.
Although they come with supplied double sided scotch tape in my experience you cannot rely on this to hold them in place.
The tamper spring is always applying pressure to force the unit from the door or window frame. The double sided tape will absorb any moisture particularly from a wooden door or in a kitchen environment leading to the unit unexpectedly detatching and causing a false alarm.
2.
Make absolutely sure that the AAA batteries in the PIR sensors are properly placed and that the contact springs are making good contact with the negative contact of the battery.
Take great care when fastening the front of the PIR sensors in place. The batteries can slip leading to a loss of contact or a poor contact. This can lead to either a sensor that doesn't work or a sensor that can heat up due to high resistance of the circuit.
Press the learn/test button before leaving any sensor to ensure the red light comes on.
If in doubt check it again.
Many reasons to steer clear of these Argos type bargains!
Who would ever consider that a pair contacts stuck on with sticky pads is something to rely on?
Yukky stuff.
I think it is only fair people to see the general consensus of opinion when it comes to kit - deleting posts and hiding others opinions seems unfair.
I also don't see the point in this thread, which eventually will just vanish pages and pages down where no one will find it. Why don't you just wait for someone to start a thread asking for help?
If you do report this to a moderator, I do hope they leave the thread as it is, or delete it in it's entirety.
