Extractor fan Burnout
24 Feb 2004
Somerset
Ducted, double insulated Extractor Fan in loft switched with the light, timed over-run.
Been working fine for several years (note date lable 5/99) ... cleaned every year.
A 2 amp fuse required by manf in the fitting instructions, was not fitted by someone who knew better .. unfortunately he was a real sparky.
First pix shows plastic deformation of the outer plastic cover, on the corner at the shadow line.
Upon stripping the fan, this next pix shows the inner shell damage plus the burnt circuit board.
If you have an extractor fan in the loft, without the required fuse ... How do you fancy this going on out of sight ? Out of mind ? Out of home!!
Hope you can see why I have had a bee in my bonnet about it.
It's an awkward little problem to fuse both Live and switched live to the fan working in conjunction with the light.
P
ofc you can't be sure the fuse would have stopped that
i think grid modules are probbablly the best way if you really wan't to fuse 2 seperate live feed to one appliance
I agree, legrand and ashley do a good range.
You don't need 2 fused feeds, and you don't need to invest in grid modules. Assuming the usual scheme of wiring the fan into the lighting circuit, controlled by the light switch, you just replace the switch with a DP one, and use a normal FCU:
If you use a switched FCU then you can do away with the 3-pole isolator, as the FCU will isolate the fan completely.
Just seen this post and is a sensible idea. Where would you mount the sfcu, could this be in the bathroom, if so which zone would you place it in?
btw does anyone know of anywhere that sells red and earth (ie one red core and a bear earth core) maplin used to sell it but don't anymore
sounds like it would be very usefull in this setup ;)
Zone 3 or outside the Zones would be OK
