- Joined
- 14 Sep 2009
- Messages
- 51
- Reaction score
- 2
- Country
Apologies for posting again on this subject but there seemed to be some confusion in the last thread I started (probably due to me) and it was suggested that I start afresh.
The layout
I live in a terraced house with a water meter situated in the pavement outside my house under a cover. This water meter is the one that is for / supplies / feeds my house ie if I use water in my house the dials on that water meter turn. Adjacent to my water meter (on the right) there is also a stopcock (hexagonal nut). I have attached a photo below.
If the neighbours turn on their water supply my water meter does not register any consumption ie dials do not turn.
Furthermore, my household's water consumption appears to be normal 475-500ltrs / day, family of four.
My terraced house is about 20 years old and the next door property with which I am having difficulties with is Victorian.
I hope that I have been clear so far.
The problem
I am having a problem with the next door terrace. Whenever they need to stop the water supply in their house (recently to replace their boiler), they turn off the stopcock (hexagonal nut) located in the pavement under the cover (to the right of my water meter). Unfortunately, when they do so the water supply to my house is also turned off.
I have now learned that my own water meter has a valve in the meter chamber in order to independently shut off my water supply. I do not know whether turning off the valve in my water meter will also turn off the neighbour’s water but I strongly believe this is not the case.
I understand that my neighbours should have an internal stopcock usually situated under the kitchen sink but they cannot locate it.
My neighbours will be completely refurbishing their house (to include bathrooms and moving their kitchen) in the next few months and I am sure that the builders will be regularly turning off the water supply.
What are my options
My objective is simply that I wanted my neighbours to be able to stop their main water without also shutting off my water. By that I mean for their to be a separate stopcock (situated close /adjacent to my water meter but) which when closed would only stop the neighbour’s water supply ie that they do not close the hexagonal nut which also stops the water supply to my house.
Would the easiest / simplest and cheapest solution be for the water utility to install a water meter to supply my neighbour’s terrace which would contain it’s own independent shut off valve, ie to solely turn off their water supply and not mine also.
Presumably if the utility did install such a meter for my neighbour’s terrace it would be situated outside in the pavement outside of their house.
Many thanks for any info provided
Cheers View media item 35754
The layout
The problem
What are my options
