It's outside - what else was I gonna do?Nice to see CW glands, Ban.
you would be surprised how many people dont use them or even know they exist
Usage of crimps for loop-in (neater re space)...
- I am certain there is a push-in type connector on the market??
- Basically 2-way 3-way 4-way etc
- Like that used on lighting, but for 2.5mm & 4.0mm CSA
Was I imagining it?
Made by Ideal or someone similar?
More compact than a terminal block, no need to screw it down, quick. Crimps via ratchet tool might be a more long term connection method though and are probably smaller.
The boxes had an uneven finish so I used the washers to make a better seal between the glands and the box.What's the purpose of fibre washers under the glands in the besa box.
I don't believe I have - at least not to the point where it is unsuitable.Why have you derated the external enclosure.
If you mean where the cable from the photocell enters the the enclosure it's not black compound it's a rubber washer.What is the purpose of that black compound.
Because that was a convenient height for it to be - I've not experienced any problems with the lights switching off because of car headlamps.Why is the photo cell at similar level to car headlamps.
<Shrug.>All looks a bit ***** to me. For the perfect ***** effect, you need a little lion with flashing red eyes on top of that brick pier and some rubbish iron gates with gold spikes.
