I would imagine he means solid core, rather than stranded.
Yup, didn't think of that.
Welcome to the world of systems install.Disi, to be honest I would need it for the whole building as more or less all routes I need to cover with the cat5e would somehow come across some mains.
The most important thing with solid vs stranded is to make sure that the terminations you use are suitable for the cable you are using. wallports and patch panels are designed for solid cable. Plugs can be bought in versions for both solid and stranded cable (if you use both make sure you don't mix them up. If the supplier doesn't say which they are for then don't buy)Stranded Cat 5 is designed for flyleads which due to movement (patching, desk top to wall point) would be unsuitable for solid Cat 5 which can break inside the sheath.
Well that will be the new and emerging, and very much non-standard type of cable to which some people are applying the tag "Cat 8", as if to imply it is a standard, and that it's just the natural progression from Cat5, Cat6, Cat7. It's neither.if it were me, I would really want a fast reliable network capable of at least 1 GHZ speed.
But heaven alone knows why you want a cable with a frequency bandwidth of 1GHz + when you can run 10Gb (can you get faster switches, routers and interfaces?) over 500MHz Cat6a, and 10Gb is 200 x the rate that a high-def DVD transfers at.
If when you were typing that you were using a high definition monitor did you know that the DVI cable is capped at 165MHz?
If you've got a state-of-the art HD TV, did you know that the latest 1.3 HDMI interface is only 340MHz, and that your shiny new Blu-Ray player will quite happily deliver full resolution video and audio through HDMI 1.0 at 165MHz?
Cat5e will do 1Gb.
I don't think he is, unless he's got a ****** big home, as he needs 250m of cable.If you are just playing at home and have the cable yes.
k4q - do the people paying you to install their network know that you know nothing about it, and did you warn them of this?
