Before I plaster the new utility room/wc i'm considering running a cable for a light on the outside of the wall, as it's next to the patio, what are the rules regarding the zone here though, the cable will be RCD protected and less than 50mm in the wall, do I need to run it down the corner of the room only or is it ok to run it down the wall then through it into the back of the outside light?
Need to make sure everythings ok as the building inspector is coming Monday morning to check i've zoned everything ok.
