Appendix 2 BS7671:2008.
Ha ha, so you can't name another one, thats all I needed to know.![]()
Apologies for interrupting your squabble.
Their meaning is as clear as the fact that you aren't capable of understanding them.They don't mean anything so choose whichever words you like to describe this fact.
But what about saying that it can't mean anything at all to anyone else?I repeat, I'm sorry people like you can't understand simple English. It may mean to you whatever it means. However, that is not the same as saying that it can't mean anything else to anyone else.
It's a pity that you don't take the same attitude regarding the question I first asked you, instead of raising irrelevant issues in an attempt to evade it.I'm not falling for that one. I asked you first as it is you who asserted that common sense is defined in Law.
I have supplied all the variables that relate to the specific question which I asked.Then supply all the variables instead of rather clumsily using a loaded gun technique.
They are when they are completely irrelevant to the question asked. And in the case of some of them irrelevant in any circumstances to the question of whether something is notifiable.I'm sorry that you think doing a proper job is pedantry. I'm sorry that you think location, length of cable run, installation method, design current etc. are the machinations of a pedant.And you criticise others for what you term "pedantry"??But I would ask which corner and exactly where?
That would be relevant to whether the work was notifiable. It is not relevant to whether the work is notifiable because of the presence of a shower nearly 200' away.I would ask if the socket were to be added to a new circuit.
They would be relevant to whether the work was notifiable. They are not relevant to whether the work is notifiable because of the presence of a shower nearly 200' away.I would ask if the socket were to be added in the kitchen, or an en-suite area, or a sauna.
And so you should. Presumably you would have a mental or written list of reasons, factors, questions, circumstances to qualify etc which you would run through to determine if a particular item of work was notifiable.In fact I would do my job properly and ascertain ALL of the facts instead of willy nilly committing my liability to such an open ended scenario.
Again an evasion - if I had such a feature then it would be relevant to the general question of whether it is notifiable.Again, not enough information. Perhaps in your avant-garde open plan living space, you have an indoor waterfall cascading down the corner in question.
I wasn't shouting. In just the same way that if I was speaking to you, and you were having trouble hearing me, I might raise my voice, I made some of the words larger because you seemed to be having trouble seeing them clearly.By the way, I thought the Forum had rules on things like shouting. So please refrain from shouting otherwise the Moderators might rebuke you.
What would be the point in saying that gibberish?But what about saying that it can't mean anything at all to anyone else?
It's a pity you attempt to use ploys that would be immature in a kindergarten. And you evaded the question.It's a pity that you don't take the same attitude regarding the question I first asked you, instead of raising irrelevant issues in an attempt to evade it.I'm not falling for that one. I asked you first as it is you who asserted that common sense is defined in Law.
Then I would say your incompetence is complete.I have supplied all the variables that relate to the specific question which I asked.Then supply all the variables instead of rather clumsily using a loaded gun technique.
You might think them irrelevant, but then you are not a professional and make a habit of slavish obedience to gibberish, mumbo jumbo and hocus-pocus.They are when they are completely irrelevant to the question asked. And in the case of some of them irrelevant in any circumstances to the question of whether something is notifiable.I'm sorry that you think doing a proper job is pedantry. I'm sorry that you think location, length of cable run, installation method, design current etc. are the machinations of a pedant.And you criticise others for what you term "pedantry"??But I would ask which corner and exactly where?
It would also be relevant as to whether the work should be certified with a Minor Works or an EIC. It would also be relevant if the extra circuit loading affected Maximum Demand and the rating of the supply and associated switchgear. I don't expect you to consider such things as such things are technical irritants in a world of monkey see - monkey do.That would be relevant to whether the work was notifiable.I would ask if the socket were to be added to a new circuit.
That depends on if the shower tray measures 200' or not. So again, your point is ridiculous and at best is 'clutching at straws'.It is not relevant to whether the work is notifiable because of the presence of a shower nearly 200' away.
You can narrow your gibberish down to fine points if it makes you feel better. It doesn't alter the fact that your presumed scenario was more full of holes than a sieve.They would be relevant to whether the work was notifiable. They are not relevant to whether the work is notifiable because of the presence of a shower nearly 200' away.I would ask if the socket were to be added in the kitchen, or an en-suite area, or a sauna.
Of course, I am a professional - unlike you. Yet for some reason, you expect me to discard all professionalism to give you an answer to a gibberish scenario. I wish you would make up your mind.And so you should. Presumably you would have a mental or written list of reasons, factors, questions, circumstances to qualify etc which you would run through to determine if a particular item of work was notifiable.In fact I would do my job properly and ascertain ALL of the facts instead of willy nilly committing my liability to such an open ended scenario.
There might be other reasons, so limiting them to just one when other factors may have more of an influence is pointless.I'm not asking you if adding this socket is notifiable because of any of the possible reasons, I'm asking you about just one in particular.
Not an evasion - just a smple observation of your inability to present a realistic scenario or commit yourself to facts.Again an evasion - if I had such a feature then it would be relevant to the general question of whether it is notifiable.Again, not enough information. Perhaps in your avant-garde open plan living space, you have an indoor waterfall cascading down the corner in question.
It might be notifiable if there were a bath 6 inches away. It sounds as though you are now getting desperate and that you have finally understood that your 'loaded' scenario is basically gibberish.It is not relevant to whether the work is notifiable because of the presence of a shower nearly 200' away.
I said this just about at the outset, yet you immediately embarked on the roundabout of gibberish.We can go around and around with you continuing to say "Ah but what if.." and me replying "That what if has no relevance to whether the work is notifiable because of the presence of a shower nearly 200' away" until the cows come home.
I am not prepared to offer an opinion on a loaded scenario that is gibberish.But each time we do it will look more and more as though you are simply trying to evade the question, and the question will remain unanswered.
Internet etiqutte is now defined by BASI wasn't shouting.By the way, I thought the Forum had rules on things like shouting. So please refrain from shouting otherwise the Moderators might rebuke you.
Is this your excuse for shouting. Pathetic. Quite pathetic.In just the same way that if I was speaking to you, and you were having trouble hearing me, I might raise my voice, I made some of the words larger because you seemed to be having trouble seeing them clearly.
Feel free, I'm not colour blind. But if the question is gibberish, I shan't answer it.Perhaps I'll try using a different colour this time.
Gibberish. Plain gibberish. It's just gibberish. Or is it mumbo jumbo? No, it's gibberish.If an avant-garde warehouse conversion resulted in a non-partitioned rectangular living space 50m x 30m, and in one corner there was a shower, would you claim that adding a socket in the diagonally opposite corner was notifiable because there was a shower nearly 200' away?
In what way are they relevant to whether the presence of a shower 200' away makes adding a socket notifiable?You might think them irrelevant, but then you are not a professional and make a habit of slavish obedience to gibberish, mumbo jumbo and hocus-pocus.
Indeed, but in what way would it be relevant to whether the presence of a shower 200' away makes adding a socket notifiable?It would also be relevant as to whether the work should be certified with a Minor Works or an EIC. It would also be relevant if the extra circuit loading affected Maximum Demand and the rating of the supply and associated switchgear.That would be relevant to whether the work was notifiable.I would ask if the socket were to be added to a new circuit.
It's a shame that you are so determined to avoid answering a simple single-issue question that you resort to denigration like this.I don't expect you to consider such things as such things are technical irritants in a world of monkey see - monkey do.
Does it?That depends on if the shower tray measures 200' or not.It is not relevant to whether the work is notifiable because of the presence of a shower nearly 200' away.
Is it? In what way would the size of the shower tray be relevant to whether the presence of a shower 200' away makes adding a socket notifiable?So again, your point is ridiculous and at best is 'clutching at straws'.
In what way is "If an avant-garde warehouse conversion resulted in a non-partitioned rectangular living space 50m x 30m, and in one corner there was a shower, would you claim that adding a socket in the diagonally opposite corner was notifiable because there was a shower nearly 200' away?" unintelligible?You can narrow your gibberish down to fine points if it makes you feel better.
Where are the holes in the simple question "If an avant-garde warehouse conversion resulted in a non-partitioned rectangular living space 50m x 30m, and in one corner there was a shower, would you claim that adding a socket in the diagonally opposite corner was notifiable because there was a shower nearly 200' away?" ?It doesn't alter the fact that your presumed scenario was more full of holes than a sieve.
Were I to be asking you for a definitive and binding answer to the question "If an avant-garde warehouse conversion resulted in a non-partitioned rectangular living space 50m x 30m, and in one corner there was a shower, would you claim that adding a socket in the diagonally opposite corner was notifiable?" then you might reasonably object that you couldn't.Of course, I am a professional - unlike you. Yet for some reason, you expect me to discard all professionalism to give you an answer to a gibberish scenario. I wish you would make up your mind.
Other factors may affect whether adding the socket is notifiable - that does not mean that each individual factor cannot be considered.There might be other reasons, so limiting them to just one when other factors may have more of an influence is pointless.I'm not asking you if adding this socket is notifiable because of any of the possible reasons, I'm asking you about just one in particular.
In what way is it unrealistic to not consider if the presence of an indoor waterfall is relevant to whether the presence of a shower 200' away makes adding a socket notifiable?Not an evasion - just a smple observation of your inability to present a realistic scenario or commit yourself to facts.
What's the relevance of the 6 inches?It might be notifiable if there were a bath 6 inches away.
I'm not at all desperate - it is not I who is trying to come up with reason after reason after reason not to answer a simple question about one factor which may or may not make an item of work notifiable.It sounds as though you are now getting desperate and that you have finally understood that your 'loaded' scenario is basically gibberish.
Maybe you think that if you keep on behaving like this then eventually the topic will get locked and you'll get away without having to answer the question.Gibberish. Plain gibberish. It's just gibberish. Or is it mumbo jumbo? No, it's gibberish.
Why?That depends on if the shower tray measures 200' or not.It is not relevant to whether the work is notifiable because of the presence of a shower nearly 200' away.
What's the matter FR - not able to explain why you think the size of the shower tray would be relevant?
You try so hard to be seen not to make assumptions, and yet you've assumed that the consumer unit is at the shower tray.I'm sure voltage drop over 200' for a socket circuit with BS1363 accessories is irrelevant in BAS7671 but it isn't in BS7671.
You can fool some fools some of the time...Here is one example in which BS7671 becomes the Law... A contract is signed in which 'activity A' will be installated in strict compliance with Regulation x,y,z of BS7671:2008'. That would be called Contract Law.
